How to install Skype on ROSA Desktop Fresh R2
sheshman
Operating system: Rosa Desktop Fresh R2
Сообщение sheshman »
Hi Friends,
I hope this is the right section for this question, i downloaded and installed ROSA Desktop Fresh R2 everything working just fine but i couldn't find how to install skype. Searched at Google and Forum but almost all topics in Russian that's why i didn't understand :) I did download rpm packages from Skype's home page when i try to install system says "Couldn't install" with some other errors, Also i'm really really rookie about linux just trying to learn, if any friend could help me about how i can install skype i'll be very appreciated.
Thanks in advance and merry christmas to all.
akdengi
Re: How to install Skype on ROSA Desktop Fresh R2
Сообщение akdengi »
Simple run
urpmi skype
sheshman
akdengi писал(а):Simple run
urpmi skype
Dear akdengi,
Thanks for quick reply, when i try to run urpmi skype from console system says "No Package Named Skype".
If you run 64-bit, check the 32-bit repos are enabled. And provide a minimal info at least about your system. :wink:
matfx
Operating system: Rosa Desktop Fresh 2012 R2
Сообщение matfx »
Yeah you need to enable 32 bit repo if you are running Rosa Desktop Fresh R2 64 bit. I have just finished installed Skype without any problem using software manager (Rpmdrake).
Pentium Dual Core E5400 4GB Ram Asus R7 240 2GB DDR3 Rosa Desktop Fresh R7 64bit
sheshman
so sorry for missing information, my system is ;Celeron 1.50 - 2GB RAM, Grundig Ultra Book. Rosa installed with "ROSA.FRESH.KDE.R2.i586.iso " file (I think my system is allready 32 bit). I'm also rookie about linux systems that's why i don't even know how to add repo :)
akdengi
Сообщение akdengi »
Run
 drakrpm-edit-media --expert
and check media like this:
http://yadi.sk/d/yotfOocLF6jjP
Try
urpmi get-skype
sheshman
akdengi писал(а):Run
Dear akdengi,
so many thanks, installed and working perfectly. :beer:
