[RESOLU] KDE 4.11 + QtCurve => patch de PULFER, OK !
D27
Сообщение D27 »
Salut,
Dans le sujet
http://forum.rosalab.ru/en/viewtopic.ph ... f3d#p20612
...il est expliqué https://bugs.kde.org/show_bug.cgi?id=299245 que dans KDE 4.11, on ne peut plus avoir les cadres de fenêtres sur les bords d'écran, lorsqu'une fenêtre est maximisée.
=> Comme je ne veux donc pas de cette version (en regression !), comment est-ce que je fais pour ne pas qu'elle s'installe, mais continuer à faire les autres mises à jour ?
Merci
Последний раз редактировалось D27 30 окт 2013, 23:54, всего редактировалось 1 раз.
Re: KDE 4.11, pas pour moi, mais comment faire ?
Please tell me what window decorator you want to have frames in maximized mode, I'll take a look if I can patch it so you can use KDE 4.11 without suffering from this regression.
D27
Сообщение D27 »
Hi Pulfer,
"QtCurve" (1.8.14 from Rosa deposit).
The configuration for this decorator is so complete and has so many fine tunings, I wonder wether you will be able to help...
Wish you luck ...and hope for me :wink:
D27 писал(а):Hi Pulfer,
I'll take a look ASAP. First I'll update it to latest 1.8.17, then check what needs to be done for frames support. I hope to start tomorrow (today working on ffmpeg 2.1, SDL 2.0.1 and some other updates).
Meanwhile you may try QtCurve 1.8.17:
32: http://abf-downloads.rosalinux.ru/rosa2012.1/container/1374492/i586/main/release/
64: http://abf-downloads.rosalinux.ru/rosa2012.1/container/1374493/x86_64/main/release/
I didn't patch it yet, just built new version to work with. KDE and GTK packages were merged into one source tarball in upstream since 1.8.17, so it required to make some work before I can patch anything. :)
I found that QtCurve already had "Remove from maximised windows" option for window frames. So I patched QtCurve to show window frames for maximised windows when that option is disabled (and it's disabled by default).
I suggest to update QtCurve from these containers if you want to have it ASAP:
32 bit: http://abf-downloads.rosalinux.ru/rosa2012.1/container/1374706/i586/main/release/
64 bit: http://abf-downloads.rosalinux.ru/rosa2012.1/container/1374707/x86_64/main/release/
Or you can wait until QA checks 1.8.17 and it's published to Main/Updates. It may take a week or more because QA is too busy now with several very important big updates.
So, the issue is resolved and you can use KDE 4.11 :)
D27
Сообщение D27 »
Hi Pulfer,
Followed your instructions...
Updated to KDE 4.11.2...
and...
EVERYTHING WORKS FINE! :Yahoo!:
The option "Remove from maximised windows" in QtCurve 1.8.17 (your container) is perfectly working.
Millions of thanks. ...We're lucky to have people like you.
Now...
...WHERE SHALL I SEND THE BEERS, GUY ?!!! :beer:
Good to know that everything is fine now :)
Вернуться в «ROSA Desktop»
