rpmdrake and others won't open from systemsettings. Solved
- benbullard79
			Should mention this in fresh install of ROSA Desktop Fresh x86_64.In systemsettings I changed a few settings in 'Configure authentication for ROSA tools' to 'no password'. Now they and others won't open giving error:
The password you typed is invalid.
Please try again.
'Configure authentication for ROSA tools' also won't open giving error:
Unknown error.
Any way to fix this?
Please try again.
Unknown error.
					Последний раз редактировалось benbullard79 11 апр 2013, 04:45, всего редактировалось 2 раза.
							Thanks,
Ben Bullard
						Ben Bullard
Re: rpmdrake and others won't open from systemsettings
Is you system fully updated ?
Pleas don't use msec, draksec, drakguard. We need fix it work, becouse they are outdated and break system!
				ejvwaasdijk
Thank you, Akdengi, for the advice.
What shall we use instead?
Why did Rosalab give us these programs that do not work instead of updating them?
Greetings,
Erik.
Greetings,
Erik.
Be patient. drakxtools-14.34-7 fix this, it pushed for repo (need some time 1-2 days for sync all repo) and you will need than simple update system with
from root CLI
Then run draksec and properly setup system.
We changed usermod pam model (from old Mandriva to Fedora for simplyfing future support and implimentation enterprise part) and now we has only two settings - root and no_password,
Also you may find newest package in my private (akdengi_personal) repo on ABF.
Thanks for report.
urpmi --auto-updateThen run draksec and properly setup system.
Thanks for report.
				ejvwaasdijk
Dear Akdengi,
the updated drakxtools arrived today on my computer. But there are still utilities that do not work: the hardware enumeration, the management of access to ROSA help programs and the management of the firewall. In fact nothing has changed.
Thank you for trying to resolve the issue.
Greetings,
Erik.
Greetings,
Erik.
Please start new topic about... This is not related to PAM error.ejvwaasdijk писал(а):Dear Akdengi,
Greetings,
Erik.
What not working? For me work OK hardrake and drakfirewall. What symptoms?
- benbullard79
Installed new packages and ran draksec and most are now working. Personal Firewall and draksec gui are 2 that still aren't working here. Should note that this is easy to work around. Simply:akdengi писал(а):Be patient. drakxtools-14.34-7 fix this, it pushed for repo (need some time 1-2 days for sync all repo) and you will need than simple update system with
from root CLIКод: Выделить всё
urpmi --auto-update
Thanks for report.
# kdesu systemsettingsBy the way what is command for 'Personal Firewall'?
Thanks,
Ben Bullard
						Ben Bullard
- benbullard79
D'oh!benbullard79 писал(а):By the way what is command for 'Personal Firewall'?
# drakfirewallThanks,
Ben Bullard
						Ben Bullard
Oh... I thinked that draksec and drakfirewall not work, but not worked run it from KDE Systemsetting... I will fix this error soon.benbullard79 писал(а):D'oh!benbullard79 писал(а):By the way what is command for 'Personal Firewall'?
# drakfirewall
