Bogue de Shutter ?
Vladimir
Operating system: Mageia2
Bogue de Shutter ?
Сообщение Vladimir »
Bonjour tout le monde,
J'ai installé Shutter (application de capture d'écran...et plus) à partir des dépôts sur ma Rosa Desktop KDE 64 bits.
Shutter se lance bien mais si je veux effectuer une capture d'écran en cliquant sur le bouton sélection, j'ai d'abord cette fenêtre qui s'affiche:
Puis si je clique sur "Show more details", c'est une seconde fenêtre qui s'affiche:
Maintenant si je lance Shutter à partir de la console j'ai cette réponse:
WARNING: gnome-web-photo is missing --> screenshots of websites will be disabled!
WARNING: Image::ExifTool is missing --> writing Exif information will be disabled!
WARNING: Gtk2::AppIndicator is missing --> there will be no icon showing up in the status bar when running Unity!
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 9: reading configurations from ~/.fonts.conf is deprecated.
INFO: new upload-plugin information detected - /usr/share/shutter/resources/system/upload_plugins/upload/Dropbox
Can't locate common/sense.pm in @INC (@INC contains: /usr/share/shutter/resources/modules /usr/lib/perl5/site_perl/5.14.2/x86_64-linux-thread-multi /usr/lib/perl5/site_perl/5.14.2 /usr/lib/perl5/vendor_perl/5.14.2/x86_64-linux-thread-multi /usr/lib/perl5/vendor_perl/5.14.2 /usr/lib/perl5/5.14.2/x86_64-linux-thread-multi /usr/lib/perl5/5.14.2 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl .) at /usr/lib/perl5/vendor_perl/5.14.2/Net/Dropbox/API.pm line 3.
BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.14.2/Net/Dropbox/API.pm line 3.
Compilation failed in require at /usr/share/shutter/resources/system/upload_plugins/upload/Dropbox.pm line 73.
BEGIN failed--compilation aborted at /usr/share/shutter/resources/system/upload_plugins/upload/Dropbox.pm line 73.
ERROR: upload-plugin exists but does not work properly - /usr/share/shutter/resources/system/upload_plugins/upload/Dropbox[/spoiler
J'ai désinstallé Shutter en supprimant tout ce qui avait un rapport avec cette application, le dossier .shutter par exemple, puis réinstallé.
Mais le problème persiste.
Quelqu'un ou quel qu'une a-t-il ou a-telle constaté ce défaut? :(
sylvainsjc
Operating system: ROSA Linux
Re: Bogue de Shutter ?
Сообщение sylvainsjc »
Salut,
J'aimais bien shutter lorsque j'utilisais Gnome mais maintenant ksnapshot me va bien avec toutes ces possibilités d'export
Sinon pour installer rien que shutter, c'est 57 paquets et 87Mo :-o
J'ai essayé et je constate aussi le même problème, dans ce cas, il faut le signaler sur bugzilla ;)
dareksmok
i5-4570 CPU @ 3.20GHz
NVIDIA GeForce GT 1030
8 GB RAM
Сообщение dareksmok »
Salut, je suis un utilisateur GNOME Rosa Marathon 2012 LTS. Après avoir installé le package à partir d'un référentiel de rosée fraîche sur mon système, le programme va également générer des problèmes similaires en poste numéro 1.
La solution était d'installer une version de Mandriva 2011-32bit.
Installez la version de Mandriva 2011 "shutter-0.86.2-1mdv2011.0.noarch.rpm" http://rpm.pbone.net/index.php3/stat/4/ ... h.rpm.html
Pour satisfaire les dépendances, ajouter des dépôts mib-base dans le terminal en tant que root.
urpmi.addmedia --update mib-basic http://mib.pianetalinux.org/MIB/rosa2012lts/32/basic/
Afin de satisfaire les dépendances seront installés les packages suivants:
Version parution Architecture DEpoch Dist Package
(transporteur "main (LTS2012.0-1)")
perl-Data-OptList 0.107.0 1 rosa> 2012.0 noarch
perl-Devel-GlobalDestruction 0.40.0 2 rosa> 2012.0 i586
perl-Eval-Closure 0.40.0 5 rosa> 2012.0 noarch
perl-File-Copy-Recursive 0.380.0 6 rosa> 2012.0 noarch
perl-File-HomeDir 0.970.0 4 rosa> 2012.0 noarch
perl-File-Which 1.90.0 4 rosa> 2012.0 noarch
perl-Gnome2 1.42.0 8 rosa> 2012.0 i586
perl-Gnome2-Canvas 1.002 15 rosa> 2012.0 i586
perl-Gnome2-VFS 1.081 6 rosa> 2012.0 i586
perl-MRO-Compat 0.110.0 5 rosa> 2012.0 noarch
perl-Moose 2.1.0 3 rosa> 2012.0 i586
perl-Package-DeprecationManag> 0.110.0 4 rosa> 2012.0 noarch
perl-Package-Stash 0.290.0 1 rosa> 2012.0 noarch
perl-Params-Util 1.40.0 3 rosa> 2012.0 i586
perl-Sub-Exporter 0.982 5 rosa> 2012.0 noarch
perl-Sub-Install 0.925 6 rosa> 2012.0 noarch
perl-Sub-Name 0.50.0 3 rosa> 2012.0 i586
perl-Try-Tiny 0.70.0 4 rosa> 2012.0 noarch
(nośnik "contrib (LTS2012.0-3)")
perl-X11-Protocol 0.560.0 1 rosa> 2012.0 noarch
(nośnik "contrib updates (LTS2012.0-4)")
gnome-web-photo 0.10.1 2 rosa> 2012.0 i586 (sugerowany)
perl-Gnome2-GConf 1.44.0 7 rosa> 2012.0 i586
perl-Gnome2-Wnck 0.160.0 1 rosa> 2012.0 i586
perl-Gtk2-ImageView 0.50.0 1 rosa> 2012.0 i586
perl-HTML-Form 6.0.0 1 rosa> 2012.0 noarch
perl-Proc-Simple 1.280.0 1 rosa> 2012.0 noarch
(nośnik "mib-basic")
perl-WWW-Mechanize 1.720.0 1 mib 2012.0 noarch
(wiersz poleceń)
shutter 0.86.2 1mdv2011.0 noarch
Va utiliser l'espace disque supplémentaire: 14MB
Le 5.8MB paquets téléchargés.
Commencez l'installation d'un paquet?
ROSA Fresh R10 MATE - 64 bit
Вернуться в «ROSA Desktop»
