High Cpu Usage
English-speaking forum for talkers =)
Cowboooy
Operating system: ROSA Marathon LTS
High Cpu Usage
Сообщение Cowboooy »
Hi everyone I'm using ROSA Desktop Fresh 2012 but since I install the Fresh CPU usually High usage and High temperature,
Local system message service Message from syslogd@cowboy at Feb 7 10:32:33 ...
kernel:[394.502218] thermal_sys: Critical temperature reached (90 C), shutting down
this dialogue appear always right bottom corner?
I have Nvidia Graphic Card 7000 series, 2 Gb RAM, 1.7 Ghz dual core processor on ASUS Notebook, I don't see any similar errors previous ROSA versions or other Linux OS's, any idea?
Re: High Cpu Usage
Same issue here. It came with the latest updates. VERY high cpu usage all the way. Shall torture the devs tomorrow :(
Cowboooy
Re: High Cpu Usage
I don't understand your suggestion here
Re: High Cpu Usage
Cowboooy писал(а):I don't understand your suggestion here
It only means that tomorrow I will ask the developers what to do with all that mess and suggest to fix it as soon as possible.
Cowboooy
Re: High Cpu Usage
oh ok devs = developers :) thank you I understand now :) I'm waiting for any suggestion thank you :)
Re: High Cpu Usage
Some updates with the workaround for this issue came today, please check.
Here's the bug actually: http://bugs.rosalinux.ru/show_bug.cgi?id=1317
Cowboooy
Re: High Cpu Usage
Problem continue, I install i586 maybe there is no same issue but nothing change, high CPU temperature, today again install x86_64 update the system but same, problem continue :( I check the link but I don't see any useful thing, they still have same problem...
Re: High Cpu Usage
Then please file a new bug. This is serious. And please give ouput of 'top' or 'htop' and 'journalctl' there in the bug.
Cowboooy
Re: High Cpu Usage
Okay I send a bug file. here is the link;
http://bugs.rosalinux.ru/show_bug.cgi?id=1664
Вернуться в «Off the wall»
