I think the subject line says it. Using a fully updated 2012.1 Beta, when I open a document in LO Writer, scroll down the page and then scroll up again, I find that text has disappeared -- not all of the text, but large sections, multiple lines, or whole paragraphs. I can click in the area where text should be, and the text magically appears again.
Anyone else having that experience? I have an ATI/AMD Radeon HD 4650 video card with the proprietary driver installed (which I hoped would solve the problem).
David
[Solved] 2012.1: disappearing text after scrolling LibreOffi
Последний раз редактировалось DShelbyD 16 дек 2012, 08:33, всего редактировалось 1 раз.
Re: 2012.1: disappearing text after scrolling LibreOffice Wr
This is known error with X-Server 13 and free radeon driver. If you has ATI/AMD card please install package
x11-driver-video-fix
Thanks very much for the help. I installed the package, but the problem persists. I suppose that over time this issue will be resolved, but for now I encounter this issue only in ROSA and Mageia Cauldron.
David
PS Wow! It seems to affect the forum also, as the word "Writer" is truncated in all but the subject line of the original post.
David
It is because I had the proprietary driver installed. As you said, x11-driver-video-fix works with the free radeon driver. Problem solved.
Re: [Solved] 2012.1: disappearing text after scrolling Libre
Semi strange that you card may work with proprietary fglrx - AMD drop support with XServer 13 card < 5xxxx
Yes, I saw that some time ago, and I expected to have trouble after installing the proprietary driver. I now have a new installation of the 2012.1 RC, did nothing to change the default X11, and installed X11-driver-video-fix. There is no problem with disappearing text.
Thanks for your help!
David
David
