Printer Setup in Rosa 2012.1 RC
linukiss
Сообщение linukiss »
I'm trying to configure an HP network printer, but the printer configuration panel does not open, of the following message
I did not install any printer setup package, use only what is in the Rosa
Последний раз редактировалось linukiss 13 сен 2013, 02:24, всего редактировалось 1 раз.
d_uragan
Re: Printer Setup in pink 2012.1 RC
Сообщение d_uragan »
Mm, smth is wrong with the image attachment - I don't see anything...
akdengi
Сообщение akdengi »
run system-config-printer...
d_uragan
linukiss писал(а):I'm trying to configure an HP network printer, but the printer configuration panel does not open, of the following message
Hm, the printer configuration panel should launch system-config-printer, it is strange that it claims about 'printer' executable.
Can you check the version of 'kcm-printer' package (show the output of "rpm -qi kcm-printer")? The freshest one has version 1.0 and release 7.
You can also check that system-config-printer tool is present and can be launched.
linukiss
after the last update everything is operating normally, sorry my bad english, I'm brazilian
Вернуться в «Desktop»
