Странности с питоном
Сквозняк
Сообщение Сквозняк »
Пытаюсь установить stable-diffusion-webui, нейросеть сообщает что установка глючит
./webui.sh
Install script for stable-diffusion + Web UI
Tested on Debian 11 (Bullseye), Fedora 34+ and openSUSE Leap 15.4 or newer.
Running on buratino user
Repo already cloned, using it as install directory
Create and activate python venv
Launching launch.py...
glibc version is 2.33
Check TCMalloc: libtcmalloc_minimal.so.4
libtcmalloc_minimal.so.4 is not linked with libpthread will trigger undefined symbol: pthread_Key_create error
Check TCMalloc: libtcmalloc.so.4
libtcmalloc.so.4 is linked with libpthread,execute LD_PRELOAD=/usr/lib64/libtcmalloc.so.4
Python 3.8.13 (default, Jul 14 2025, 13:31:28)
[GCC 11.4.0 20230528 (ROSA)]
Version: v1.10.1-96-g1937682a
Commit hash: 1937682a20f7f0442311a1ede68f9f0cb480163b
Installing requirements
  File "launch.py", line 53, in <module>
    main()
  File "launch.py", line 44, in main
    prepare_environment()
  File "/mnt/kabacok3/1/2/nnn/1/stable-diffusion-webui/modules/launch_utils.py", line 471, in prepare_environment
    run_pip(f"install -r \"{requirements_file}\"", "requirements")
  File "/mnt/kabacok3/1/2/nnn/1/stable-diffusion-webui/modules/launch_utils.py", line 142, in run_pip
    return run(f'"{python}" -m pip {command} --prefer-binary{index_url_line}', desc=f"Installing {desc}", errdesc=f"Couldn't install {desc}", live=live)
  File "/mnt/kabacok3/1/2/nnn/1/stable-diffusion-webui/modules/launch_utils.py", line 114, in run
    raise RuntimeError("\n".join(error_bits))
RuntimeError: Couldn't install requirements.
Command: "/mnt/kabacok3/1/2/nnn/1/stable-diffusion-webui/venv/bin/python" -m pip install -r "requirements_versions.txt" --prefer-binary
Error code: 1
stdout: Collecting setuptools==69.5.1 (from -r requirements_versions.txt (line 1))
  Using cached setuptools-69.5.1-py3-none-any.whl.metadata (6.2 kB)
Collecting GitPython==3.1.32 (from -r requirements_versions.txt (line 2))
  Using cached GitPython-3.1.32-py3-none-any.whl.metadata (10.0 kB)
Collecting Pillow==9.5.0 (from -r requirements_versions.txt (line 3))
  Using cached Pillow-9.5.0-cp38-cp38-manylinux_2_28_x86_64.whl.metadata (9.5 kB)
Collecting accelerate==0.21.0 (from -r requirements_versions.txt (line 4))
  Using cached accelerate-0.21.0-py3-none-any.whl.metadata (17 kB)
Collecting blendmodes==2022 (from -r requirements_versions.txt (line 5))
  Using cached blendmodes-2022-py3-none-any.whl.metadata (12 kB)
Collecting clean-fid==0.1.35 (from -r requirements_versions.txt (line 6))
  Using cached clean_fid-0.1.35-py3-none-any.whl.metadata (36 kB)
Collecting diskcache==5.6.3 (from -r requirements_versions.txt (line 7))
  Using cached diskcache-5.6.3-py3-none-any.whl.metadata (20 kB)
Collecting einops==0.4.1 (from -r requirements_versions.txt (line 8))
  Using cached einops-0.4.1-py3-none-any.whl.metadata (10 kB)
Collecting facexlib==0.3.0 (from -r requirements_versions.txt (line 9))
  Using cached facexlib-0.3.0-py3-none-any.whl.metadata (4.6 kB)
Collecting fastapi==0.94.0 (from -r requirements_versions.txt (line 10))
  Using cached fastapi-0.94.0-py3-none-any.whl.metadata (25 kB)
Collecting gradio==3.41.2 (from -r requirements_versions.txt (line 11))
  Using cached gradio-3.41.2-py3-none-any.whl.metadata (17 kB)
Collecting httpcore==0.15 (from -r requirements_versions.txt (line 12))
  Using cached httpcore-0.15.0-py3-none-any.whl.metadata (15 kB)
Collecting inflection==0.5.1 (from -r requirements_versions.txt (line 13))
  Using cached inflection-0.5.1-py2.py3-none-any.whl.metadata (1.7 kB)
Collecting jsonmerge==1.8.0 (from -r requirements_versions.txt (line 14))
  Using cached jsonmerge-1.8.0.tar.gz (26 kB)
  Preparing metadata (setup.py): started
  Preparing metadata (setup.py): finished with status 'done'
Collecting kornia==0.6.7 (from -r requirements_versions.txt (line 15))
  Using cached kornia-0.6.7-py2.py3-none-any.whl.metadata (12 kB)
Collecting lark==1.1.2 (from -r requirements_versions.txt (line 16))
  Using cached lark-1.1.2-py2.py3-none-any.whl.metadata (1.7 kB)
stderr: ERROR: Could not find a version that satisfies the requirement numpy==1.26.2 (from versions: 1.3.0, 1.4.1, 1.5.0, 1.5.1, 1.6.0, 1.6.1, 1.6.2, 1.7.0, 1.7.1, 1.7.2, 1.8.0, 1.8.1, 1.8.2, 1.9.0, 1.9.1, 1.9.2, 1.9.3, 1.10.0.post2, 1.10.1, 1.10.2, 1.10.4, 1.11.0, 1.11.1, 1.11.2, 1.11.3, 1.12.0, 1.12.1, 1.13.0, 1.13.1, 1.13.3, 1.14.0, 1.14.1, 1.14.2, 1.14.3, 1.14.4, 1.14.5, 1.14.6, 1.15.0, 1.15.1, 1.15.2, 1.15.3, 1.15.4, 1.16.0, 1.16.1, 1.16.2, 1.16.3, 1.16.4, 1.16.5, 1.16.6, 1.17.0, 1.17.1, 1.17.2, 1.17.3, 1.17.4, 1.17.5, 1.18.0, 1.18.1, 1.18.2, 1.18.3, 1.18.4, 1.18.5, 1.19.0, 1.19.1, 1.19.2, 1.19.3, 1.19.4, 1.19.5, 1.20.0, 1.20.1, 1.20.2, 1.20.3, 1.21.0, 1.21.1, 1.21.2, 1.21.3, 1.21.4, 1.21.5, 1.21.6, 1.22.0, 1.22.1, 1.22.2, 1.22.3, 1.22.4, 1.23.0, 1.23.1, 1.23.2, 1.23.3, 1.23.4, 1.23.5, 1.24.0, 1.24.1, 1.24.2, 1.24.3, 1.24.4)
ERROR: No matching distribution found for numpy==1.26.2
из-за версии питона - 3.8 там уже не подерживается, надо 3.9, ставлю новую версию
dnf in python3.12-*
Ошибка остаётся. Проверяю версию питона, а там:
$ python3 --version
Python 3.8.13
Re: Странности с питоном
Это не меняет системный python. Попробуйте через venv.
$ python3.12 -m venv venv
$ source venv/bin/activate
$ ./webui.sh
Сквозняк
Вроде питон нужной версии работает. Но запустилось что-то не то. У меня X11, а не вайланд, а тут попытка работы через вайланд валится:
buratino@rosa-ka1byt /mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge (main) $ python3.10 -m venv venv && source venv/bin/activate && ./webui.sh
python venv already activate or run without venv: /mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/venv
Python 3.10.14 (main, Jun 26 2026, 23:22:29) [GCC 11.4.0 20230528 (ROSA)]
Version: f2.0.1v1.10.1-previous-669-gdfdcbab6
Commit hash: dfdcbab685e57677014f05a3309b48cc87383167
Legacy Preprocessor init warning: Unable to install insightface automatically. Please try run `pip install insightface` manually.
Launching Web UI with arguments:
/mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/venv/lib/python3.10/site-packages/torch/cuda/__init__.py:209: UserWarning:
NVIDIA GeForce RTX 5060 Ti with CUDA capability sm_120 is not compatible with the current PyTorch installation.
The current PyTorch install supports CUDA capabilities sm_50 sm_60 sm_70 sm_75 sm_80 sm_86 sm_90.
If you want to use the NVIDIA GeForce RTX 5060 Ti GPU with PyTorch, please check the instructions at https://pytorch.org/get-started/locally/
  warnings.warn(
Total VRAM 15886 MB, total RAM 95391 MB
pytorch version: 2.3.1+cu121
Set vram state to: NORMAL_VRAM
Device: cuda:0 NVIDIA GeForce RTX 5060 Ti : native
Hint: your device supports --cuda-malloc for potential speed improvements.
VAE dtype preferences: [torch.bfloat16, torch.float32] -> torch.bfloat16
CUDA Using Stream: False
Using pytorch cross attention
Using pytorch attention for VAE
ControlNet preprocessor location: /mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/models/ControlNetPreprocessor
*** Error loading script: soft_inpainting.py
      File "/mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/modules/scripts.py", line 525, in load_scripts
        script_module = script_loading.load_module(scriptfile.path)
      File "/mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/modules/script_loading.py", line 13, in load_module
        module_spec.loader.exec_module(module)
      File "<frozen importlib._bootstrap_external>", line 883, in exec_module
      File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
      File "/mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/extensions-builtin/soft-inpainting/scripts/soft_inpainting.py", line 10, in <module>
        from joblib import Parallel, delayed, cpu_count
    ModuleNotFoundError: No module named 'joblib'
2026-06-27 18:10:51,509 - ControlNet - INFO - ControlNet UI callback registered.
Model selected: {'checkpoint_info': {'filename': '/mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/models/Stable-diffusion/v1-5-pruned.ckpt', 'hash': 'a9263745'}, 'additional_modules': [], 'unet_storage_dtype': None}
Using online LoRAs in FP16: False
Running on local URL:  http://127.0.0.1:7860
To create a public link, set `share=True` in `launch()`.
QObject::moveToThread: Current thread (0x319d80f0) is not the object's thread (0x319d82c0).
Cannot move to target thread (0x319d80f0)
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "/mnt/kabacok3/1/2/nnn/3/stable-diffusion-webui-forge/venv/lib/python3.10/site-packages/cv2/qt/plugins" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: xcb, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx.
/usr/bin/xdg-open: строка 686: 27752 Аварийный останов         (стек памяти сброшен на диск) "kde-open${KDE_SESSION_VERSION}" "$1"
Startup time: 7.8s (prepare environment: 1.2s, launcher: 0.2s, import torch: 3.0s, other imports: 0.2s, load scripts: 0.9s, create ui: 1.2s, gradio launch: 0.9s).
QObject::moveToThread: Current thread (0x74f20f0) is not the object's thread (0x74f22c0).
Cannot move to target thread (0x74f20f0)
/usr/bin/xdg-open: строка 686: 27762 Аварийный останов         (стек памяти сброшен на диск) "kde-open${KDE_SESSION_VERSION}" "$1"
Сервер вроде как с той ошибкой запускается, но при попытке сгенерировать изображение, выдаёт ошибку куды.
Сквозняк
Забил я на эту версию нейросети переобмазанную устаревшим питоном. Собрал stable-diffusion.cpp которая хоть и с консольным интерфейсом, но работает и к ней подходят энвидиевские пакеты куды от восьмого рхела. Может и интерфейс какой прикручивается, не изучал пока вопрос.
tihij
Operating system: ROSA Fresh KDE 12.5.1
Сообщение tihij »
Попробуйте на замену:
- EasyDiffusion (https://github.com/easydiffusion/easydiffusion);
- ComfyUI (https://github.com/Comfy-Org/ComfyUI).
Только виртуальное окружение python в обоих случаях тоже настраивать надо, чтобы систему не захламлять.
