What's wrong with my mount partitions
Non-Desktop related topics
sylvainsjc
Operating system: ROSA Linux
Сообщение sylvainsjc »
hello,
Here what I have in my /etc/fstab (sda is an SSD, sdb an IDE 320Gb Disk
[sylvain@rosa2012lts ~]$ cat /etc/fstab
# Entry for /dev/sda1 :
UUID=862a84f6-fbb0-41cd-a2ea-b4b72685c9b1 / ext4 noatime 1 1
# Entry for /dev/sda5 :
UUID=643bf6ad-821c-4b95-b8e6-3c3ef1092ba6 /home ext4 acl,noatime 1 2
# Entry for /dev/sdb3 :
UUID=e13a45c5-edc0-43dc-8e36-984cbb7db322 /mnt/datas ext4 defaults 1 2
none /proc proc defaults 0 0
# Entry for /dev/sdb1 :
UUID=94670e85-0a3f-486b-afc1-c95989e800d3 swap swap defaults 0 0
here is what I see with mount -l command :
[sylvain@rosa2012lts ~]$ mount -l
hugetlbfs on /dev/hugepages type hugetlbfs (rw)
mqueue on /dev/mqueue type mqueue (rw)
debugfs on /sys/kernel/debug type debugfs (rw)
none on /proc type proc (rw)
securityfs on /sys/kernel/security type securityfs (rw)
sunrpc on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
gvfs-fuse-daemon on /home/live/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=live)
fusectl on /sys/fs/fuse/connections type fusectl (rw)
/dev/sda1 on /mnt/install type ext4 (rw,noatime) [ssdsys]
/dev/sda5 on /mnt/install/home type ext4 (rw,noatime,acl) [ssdhome]
none on /mnt/install/proc type proc (rw)
none on /mnt/install/sys type sysfs (rw)
none on /mnt/install/proc/bus/usb type usbfs (rw)
/dev/sda1 on / type ext4 (rw,noatime,commit=0) [ssdsys]
/dev/sda5 on /home type ext4 (rw,noatime,acl,commit=0) [ssdhome]
/dev/sdb3 on /mnt/datas type ext4 (rw) [datas]
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
/dev/sdb3 on /mnt/datas type ext4 (rw,commit=0) [datas]
tmpfs on /media type tmpfs (rw,noexec,nosuid,nodev,mode=755)
/dev/sdg1 on /media/CORSAIRSZ type vfat (rw,nosuid,nodev,uhelper=udisks,uid=1010,gid=1010,shortname=mixed,dmask=0077,utf8=1,showexec) [CORSAIRSZ]
here is what I see with df -h command :
[root@rosa2012lts ~]# df -h
df: « /home/live/.gvfs »: Aucun fichier ou dossier de ce type
df: « /sys/fs/fuse/connections »: Aucun fichier ou dossier de ce type
df: « /mnt/install/home »: Aucun fichier ou dossier de ce type
df: « /mnt/install/sys »: Aucun fichier ou dossier de ce type
df: « /mnt/install/proc/bus/usb »: Aucun fichier ou dossier de ce type
Sys. de fichiers Taille Util. Disp. Uti% Monté sur
/dev/sda1 12G 6,7G 4,3G 62% /mnt/install
/dev/sda5 20G 12G 8,0G 59% /home
/dev/sdb3 233G 193G 29G 88% /mnt/datas
tmpfs 2,0G 0 2,0G 0% /media
/dev/sdg1 7,6G 1,9G 5,7G 25% /media/CORSAIRSZ
So, what's wrong ?
sylvainsjc
Re: What's wrong with my mount partitions
are you all in vacation guys ?
As though it is loaded with livecd.
From where it /home/live/, /mnt/install/?
In fstab /dev/sda1 /
And here /dev/sda1 /mnt/install
sylvainsjc
I solved the problem by booting from a live DVD and deleting the file /etc /mtab on my hard drive.
I also see the same problem with another ROSA 2012 installed in Virtualbox. Why? Am I alone with this behavior ?
While only you. Perhaps the problem is with SSD.
Maybe you need to install kernel 3.4.4
http://abf.rosalinux.ru/downloads/kerne ... n/release/
or kernel-netbook
Does anybody here use helpdesk at all..? really prefer waiting for ages on forums..? :roll:
benbullard79
Operating system: ROSA Fresh R5
OpenMandriva Lx 2014.1
openSuSE 13.2
Сообщение benbullard79 »
I haven't used helpdesk yet. I'll give it a try though.
Thanks,
Ben Bullard
benbullard79
openSuSE 13.2
VictorR2007 писал(а):While only you. Perhaps the problem is with SSD.
or kernel-netbook
Those links don't open here. I'm in 2012 Bernie Lomax now. I'll have to log into Rosa 2012 in a while and see...
Thanks,
Ben Bullard
These are not very good
or kernel-netbook
These are not very good. Look http://mib.pianetalinux.org/MIB/rosa201 ... ls/3.2.20/
benbullard79
openSuSE 13.2
Good to know. That's what I'm using.
kernel-nrj-desktop-3.2.20-1rosa.lts-1-1-rosa.lts2012.0.x86_64
kernel-nrj-desktop-devel-3.2.20-1rosa.lts-1-1-rosa.lts2012.0.x86_64
Thanks,
Ben Bullard
sylvainsjc
Can someone past here the content of his mtab file ?
I think that this file isn't completely reinitialized at reboot
I have the same in kernel 3.0.28
