OpenBabel: aggiornamento/update 2.4.1 -> 3.3.1
MikiLinux
Operating system: Rosa13
Сообщение MikiLinux »
всем привет. как дела? :beer:
ho aggiornato alla versione 3.3.1 il pacchetto "OpenBabel".
In allegato il file "openbabel-3.1.1-1.spec_patch_file.zip" contenente tante modifiche; ovviamente verificatelo, correggetelo in caso di errori, e se volete aggiungetelo al vostro repository.
Test conversione 2D->3D con interfaccia grafica (2D->3D conversion with GUI).
Come da immagine allegata funziona senza alcun problema, da linea di comando e da GUI (confrontato anche con la versione online):
https://www.cheminfo.org/Chemistry/Chem ... index.html
Tutte le prove seguono fedelmente questo tutorial:
https://www.youtube.com/watch?v=Er_dFw3KWqE
La verifica del risultato 2D/3D è stata fatta con questo visualizzatore 2D/3D online
https://miew.opensource.epam.com/
Saluti
Hi,
I have update "openBabel" software to 3.3.1 version. Enclosed "openbabel-3.1.1-1.spec_patch_file.zip" with a lot of changes; verify it - correct it in case of errors - then add in your repo.
It works very well (image enclosed), no problem at all. from command line and GUI (also compared with online version):
All tests faithfully follow this tutorial:
2D/3D result verification was done with this online 2D/3D viewer
Bye.
(27.53 КБ) 114 скачиваний
Desktop: Rosa13 KDE/Plasma
PC Lab: Rosa13 XFCE
Laptop: Rosa13 LxQt
https://elettrolinux.com
Hi, a you build for 2023.1 or 2021.1 platfom?
see my changes for 2023.1 https://abf.io/import/openbabel/commits/rosa2023.1
MikiLinux
Piattaforma 2021.1
Come posso installare la versione 2023.1? Dove scarico il file .iso?
################à
2021.1 platform.
How do I install version 2023.1? Where I download .ISO file?
PC Lab: Rosa13 XFCE
Laptop: Rosa13 LxQt
MikiLinux писал(а): 13 сен 2024, 11:30 How do I install version 2023.1? Where I download .ISO file?
https://abf.io/platforms/rosa2023.1/products/
MikiLinux
:good:
va9(2) писал(а): 13 сен 2024, 14:09
PC Lab: Rosa13 XFCE
Laptop: Rosa13 LxQt
