How do I remove recent documents (and and change other settings) from Rosa's "Simple Welcome"?
Greetings
Erik Jan
[Solved] Change settings Rosa Simple Welcome
ejvwaasdijk
Последний раз редактировалось ejvwaasdijk 14 фев 2013, 17:57, всего редактировалось 1 раз.
Re: Change settings Rosa Simple Welcome
So you can clean or some settings in "kmenuedit"
You can not do this for ROSA Marathon 2012. This feature is implemented only for ROSA Desktop Fresh 2012.ejvwaasdijk писал(а):How do I remove recent documents (and and change other settings) from Rosa's "Simple Welcome"?
Greetings
Erik Jan
ejvwaasdijk
Thank you, kda and Victor,
for your speedy replies. The problem is, that I installed Marathon EE LTS, because the user will need a desktop that is stable and maintained for a long time. I shall not have the oportunity to frequently reinstall fresh versions. In the LTS version there is no icon as indicated by Victor. But there must be some file somewhere in the home directory that contains the names of the recently opened documents. I cannot find this file. So I hope some reader of this forum will know.
Thanks in advance and greetings,
Erik Jan.
Erik Jan.
Look here ~/.kde4/share/apps/RecentDocuments/ejvwaasdijk писал(а):Thank you, kda and Victor,
Erik Jan.
ejvwaasdijk
Yes, that is the one!
Thank you very much.
Erik Jan
Erik Jan
