First I get this after update:
The following packages have bad signatures:
/var/cache/urpmi/rpms/drakx-finish-install-13.61-14-rosa.lts2012.0.x86_64.rpm: Invalid Key ID (OK (DSA/SHA1, Wed 15 Aug 2012 03:20:09 PM CEST, Key ID 409d3f00261e1b28))
/var/cache/urpmi/rpms/drakxtools-13.61-14-rosa.lts2012.0.x86_64.rpm: Invalid Key ID (OK (DSA/SHA1, Wed 15 Aug 2012 03:20:03 PM CEST, Key ID 409d3f00261e1b28))
/var/cache/urpmi/rpms/drakxtools-backend-13.61-14-rosa.lts2012.0.x86_64.rpm: Invalid Key ID (OK (DSA/SHA1, Wed 15 Aug 2012 03:20:08 PM CEST, Key ID 409d3f00261e1b28))
/var/cache/urpmi/rpms/drakxtools-curses-13.61-14-rosa.lts2012.0.x86_64.rpm: Invalid Key ID (OK (DSA/SHA1, Wed 15 Aug 2012 03:20:03 PM CEST, Key ID 409d3f00261e1b28))
/var/cache/urpmi/rpms/harddrake-13.61-14-rosa.lts2012.0.x86_64.rpm: Invalid Key ID (OK (DSA/SHA1, Wed 15 Aug 2012 03:20:09 PM CEST, Key ID 409d3f00261e1b28))
/var/cache/urpmi/rpms/harddrake-ui-13.61-14-rosa.lts2012.0.x86_64.rpm: Invalid Key ID (OK (DSA/SHA1, Wed 15 Aug 2012 03:20:09 PM CEST, Key ID 409d3f00261e1b28))Код: Выделить всё
sudo urpmi --auto-update --auto --forceКод: Выделить всё
More information on package mandriva-release-common-2012.0-8-rosa.lts2012.0.x86_64
This is ROSA Linux 2012.0
You can find the release notes in /usr/share/doc/mandriva-release-common/release-notes-en.txt
or on the web at http://wiki.rosalab.ru/en/index.php/Release_notes_ROSA_Marathon_2012
I am confused.
Would someone please explain what's happened? I really would like to understand this.
