Отдал основной ПК в ремонт и решил поиграть на стареньком ноутбуке, но steam на нём отказывается запускаться. В терминале выдаёт следующее:
~ $ steam
steam.sh[72393]: Running Steam on rosa 13.2 64-bit
steam.sh[72393]: STEAM_RUNTIME is enabled automatically
setup.sh[72448]: Steam runtime environment up-to-date!
steam.sh[72393]: Log already open
steam.sh[72393]: Steam client's requirements are satisfied
CProcessEnvironmentManager is ready, 5 preallocated environment variables.
[2026-09-05 20:30:36] Startup - updater built Sep 3 2026 01:31:48
[2026-09-05 20:30:36] Startup - Steam Client launched with: '/home/oleg/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
09/05 20:30:36 minidumps folder is set to /tmp/dumps
09/05 20:30:36 Init: Installing breakpad exception handler for appid(steam)/version(1788400362)/tid(72528)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2026-09-05 20:30:36] Process started with command-line: '/home/oleg/.local/share/Steam/ubuntu12_32/steam' '-child-update-ui' '-child-update-ui-socket' '8' '-srt-logger-opened'
[2026-09-05 20:30:36] Using update UI: console
09/05 20:30:36 Init: Installing breakpad exception handler for appid(steam)/version(0)/tid(72529)
[2026-09-05 20:30:36] Create window
[2026-09-05 20:30:36] Loading cached metrics from disk (/home/oleg/.local/share/Steam/package/steam_client_metrics.bin)
[2026-09-05 20:30:36] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2026-09-05 20:30:36] Using the following download hosts for Public, Realm steamglobal
[2026-09-05 20:30:36] 1. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2026-09-05 20:30:36] Checking for update on startup
[2026-09-05 20:30:36] Checking for available updates...
[2026-09-05 20:30:36] Downloading manifest: https://client-update.steamstatic.com/steam_client_ubuntu12
[2026-09-05 20:30:36] Manifest download: send request
[2026-09-05 20:30:36] Set percent complete: 0
[2026-09-05 20:30:36] Set status message: Checking for available updates...
[ 0%] Checking for available updates...
[2026-09-05 20:30:36] Set percent complete: -1
[2026-09-05 20:30:37] Manifest download: waiting for download to finish
[2026-09-05 20:30:37] Manifest download: finished
[2026-09-05 20:30:37] Download skipped: /steam_client_ubuntu12 version 1788400362, installed version 1788400362, existing pending version 0
[2026-09-05 20:30:37] Nothing to do
[2026-09-05 20:30:37] Verifying installation...
[2026-09-05 20:30:37] Verifying all executable checksums
[2026-09-05 20:30:37] Set percent complete: -1
[2026-09-05 20:30:37] Set status message: Verifying installation...
[----] Verifying installation...
[2026-09-05 20:30:38] Show window
[2026-09-05 20:30:43] Verification complete
UpdateUI: skip show logo
[2026-09-05 20:30:43] Destroy window
[2026-09-05 20:30:44] ProcessNextMessage: socket disconnected
[2026-09-05 20:30:44] No more messages are expected - exiting
Steam logging initialized: directory: /home/oleg/.local/share/Steam/logs
OpenGL GLX extension not supported by display
OpenGL GLX extension not supported by displayXOpenIM() failed, LANG = ru_RU.UTF-8
XOpenIM() failed, LANG = ru_RU.UTF-8XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf710f3d0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf710d920
Xlib: extension "GLX" missing on display ":0".
09/05 20:30:44 minidumps folder is set to /tmp/dumps
09/05 20:30:44 Init: Installing breakpad exception handler for appid(steamsysinfo)/version(1788400362)/tid(72535)
Running query: 1 - GpuTopology
MESA-INTEL: warning: Ivy Bridge Vulkan support is incomplete
Response: gpu_topology {
gpus {
name: "Intel(R) HD Graphics 4000 (IVB GT2)"
vram_size_bytes: 1610612736
driver_id: k_EGpuDriverId_MesaIntel
driver_version_major: 26
driver_version_minor: 1
driver_version_patch: 8
luid: 0
default_gpu_id: 1
Exit code: 0
Saving response to: /tmp/steamgdbEej - 61 bytes
steamwebhelper.sh[72540]: Starting steamwebhelper under bootstrap steamrt steam runtime via: /home/oleg/.local/share/Steam/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
steamwebhelper.sh[72540]: Starting steamwebhelper with steamrt steam runtime at /home/oleg/.local/share/Steam/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
src/vgui2/src/surface_linux.cpp (1958) : glXChooseVisual failed
src/vgui2/src/surface_linux.cpp (1958) : Fatal assert; application exiting
09/05 20:30:45 Init: Installing breakpad exception handler for appid(steam)/version(1788400362)/tid(72528)
assert_20260905203045_9.dmp[72575]: Uploading dump (out-of-process)
/tmp/dumps/assert_20260905203045_9.dmp
oleg@rosa-zf5qpt ~ $ assert_20260905203045_9.dmp[72575]: Finished uploading minidump (out-of-process): success = no
assert_20260905203045_9.dmp[72575]: error: Peer certificate cannot be authenticated with given CA certificates
assert_20260905203045_9.dmp[72575]: file ''/tmp/dumps/assert_20260905203045_9.dmp'', upload no: ''Peer certificate cannot be authenticated with given CA certificates''
exec ./steamwebhelper -nocrashdialog -lang=en_US -cachedir=/home/oleg/.local/share/Steam/config/htmlcache -steampid=72528 -buildid=1788400362 -steamid=0 -logdir=/home/oleg/.local/share/Steam/logs -uimode=7 -startcount=0 -steamuniverse=Public -realm=Global -clientui=/home/oleg/.local/share/Steam/clientui -steampath=/home/oleg/.local/share/Steam/ubuntu12_32/steam -launcher=0 -use_xcomposite_workaround --valve-enable-site-isolation --enable-smooth-scrolling --password-store=basic --log-file=/home/oleg/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-component-update --gaia-url=http://disabled.invalid --enable-features=PlatformHEVCDecoderSupport --disable-features=WinRetrieveSuggestionsOnlyOnDemand,SpareRendererForSitePerProcess,DcheckIsFatal,BlockPromptsIfIgnoredOften,WebUsbDeviceDetection,ValveFFmpegAllowLowDelayHEVC
