# rpm -qa |grep lua
lib64lua5.3-5.3.6-9.x86_64
lib64lua5.4-5.4.7-2.x86_64
lib64tolua++5.3-1.0.93-8.x86_64
tolua++-1.0.93-8.x86_64
lua-posix-36.2.1-1.x86_64
lua-5.4.7-2.x86_64Код: Выделить всё
Обновлен:
lib64rpm9-2:4.17.0-21.x86_64 lib64rpmbuild9-2:4.17.0-21.x86_64 python3-rpm-2:4.17.0-21.x86_64 rpm-2:4.17.0-21.x86_64 rpm-plugin-audit-2:4.17.0-21.x86_64
rpm-plugin-ima-2:4.17.0-21.x86_64 rpm-plugin-syslog-2:4.17.0-21.x86_64 rpm-plugin-systemd-inhibit-2:4.17.0-21.x86_64
Установлен:
autoconf-1:2.72-1.noarch automake-1.16.5-1.noarch chrpath-0.18-1.x86_64 cmake-rpm-generators-1:3.31.1-2.noarch
debugedit-5.2-1.x86_64 devel-rpm-generators-0.15-2.noarch dwz-0.15-1.x86_64 efi-srpm-macros-5-1.noarch
elfutils-0.192-1.x86_64 enchant2-2.7.3-1.x86_64 gcc-14.3.0-4.x86_64 gcc-cpp-14.3.0-4.x86_64
gdb-15.2-2.x86_64 go-srpm-macros-3.6.0-1.noarch lib64atomic-devel-14.3.0-4.x86_64 lib64cc1_0-14.3.0-4.x86_64
lib64dbginfod1-0.192-1.x86_64 lib64gcc-devel-14.3.0-4.x86_64 libtool-base-2.4.7-3.x86_64 make-1:4.4.1-1.x86_64
order-rpm-generators-2-1.noarch pam-rpm-generators-2-1.noarch python3-enchant-3.2.2-1.noarch python3-python-magic-0.4.27-2.noarch
qml-rpm-generators-0.3-2.noarch rpm-build-2:4.17.0-21.x86_64 rpm-plugin-selinux-2:4.17.0-21.x86_64 rpm-rosa-setup-build-1.0-12.git0dfc1f.noarch
rpmlint-1:1.11-23.noarch rpmlint-rosa-policy-0.3.24-14.noarch spec-helper-0.31.56-2.noarch
Выполнено!
# rpm -qa | grep lua
PANIC: unprotected error in call to Lua API (version mismatch: app. needs 503,0, Lua core provides 504,0)Код: Выделить всё
rpm: error while loading shared libraries: liblua.so.5.3: cannot open shared object file: No such file or directory
rpm: error while loading shared libraries: liblua.so.5.4: cannot open shared object file: No such file or directoryКод: Выделить всё
# ldd /usr/bin/rpm | grep lua
liblua.so.5.4 => /usr/lib64/liblua.so.5.4 (0x00007f354274a000)
liblua.so.5.3 => /usr/lib64/liblua.so.5.3 (0x00007f35422c9000)то картина не меняется
восстановить систему можно только ручным копированием содержимого старого пакета в систему поверх существующих файлов
у кого случилась/случится такая беда, можете взять архив пакета из вложения к этому сообщению, распаковывайте под root, иначе владелец на файлах слетит
