Aggiornamento/Update KiCAD 8.0.6 --> 9.0.0
MikiLinux
Operating system: Rosa13
Сообщение MikiLinux »
Salve,
aggiornato Kicad alla versione 9.0.0 (in allegato spec file & C. nel formato zip). :)
NOTA: La versione 9 non compila su Rosa2021.1, necessarie alcune aggiunte software e aggiornamenti (e.g. aggiunta pacchetto NNG, aggiornamento software Protobuf ecc).
Hi,
I have update Kicad to the 9.0.0 version (enclosed zip file).
NOTE: Version 9 does not compile on Rosa2021.1, some software additions and updates needed (e.g. add NNG sw package, Protobuf software update etc.)
As usual checking/correcting/testing any errors and add the changes to the repository.
kicad-9.0.0-1.src.zip
(20.85 КБ) 63 скачивания
Desktop: Rosa13.2 KDE/Plasma
PC Lab: Rosa13.2 XFCE
Laptop: Rosa13.2 LxQt
https://elettrolinux.com
MikiLinux
Re: Aggiornamento/Update KiCAD 8.0.6 --> 9.0.0
Gestione Progetti/Project Manager
Disegno schema elettrico/Electrical diagram drawing
PCB/Printed CIrcuit Board
3D Vis.
3D rendering
