Firefox show only a blue page
deusdara
Сообщение deusdara »
Hellow
Could someone help me.
Firefox on Rosa Fresh R12 do not show anything when it is opened.
I can see only a blue page.
Thank you in advance.
Mobo: Asus B85M-E/BR ][CPU: Intel Core i7 4790@3.6 GHz][RAM2x4 GB 1333 MHz DDR3 Kingston][GPU: onboard Intel HD Graphics 4600][HD:Seagate 1,0 TB SATA II][Fonte: Corsair CX 750 W][Rosa Desktop.Fresh 12.4]
start firefox from console, may be see error messages?
deusdara
Hello
I can not understand what is
$ firefox
(firefox-default:24093): Gtk-WARNING **: 18:32:17.545: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:24093): Gtk-WARNING **: 18:32:17.545: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
(firefox-default:24093): Gtk-WARNING **: 18:32:17.955: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:24093): Gtk-WARNING **: 18:32:17.955: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
(firefox-default:24093): Gtk-WARNING **: 18:32:18.032: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:24093): Gtk-WARNING **: 18:32:18.032: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
(firefox-default:24093): Gtk-WARNING **: 18:32:18.058: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:24093): Gtk-WARNING **: 18:32:18.058: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
ATTENTION: default value of option mesa_glthread overridden by environment.
[ERROR glean_core] Error setting metrics feature config: Json(Error("EOF while parsing a value", line: 1, column: 0))
This seems to be a problem with the new mesa.
It appeared after updating the mesa on some machines.
On some machines, updating to a new x11-server helps.
You can also try updating.
To do this, you need to make files with additional repositories,
and then update.
As root in /etc/yum.repos.d/ create x11.repo file and write there:
x11]
name=x11
baseurl=http://abf-downloads.rosalinux.ru/x11_backports_personal/repository/rosa2021.1/x86_64/main/release/
gpgcheck=0
enabled=1
cost=998
[x11-32]
name=x11-32
baseurl=http://abf-downloads.rosalinux.ru/x11_backports_personal/repository/rosa2021.1/i686/main/release/
gpgcheck=0
enabled=1
cost=1000
deusdara
Hi
It did not work.
Thank you for your help.
$ firefox
(firefox-default:2772): Gtk-WARNING **: 20:45:44.410: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:2772): Gtk-WARNING **: 20:45:44.410: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
(firefox-default:2772): Gtk-WARNING **: 20:45:44.553: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:2772): Gtk-WARNING **: 20:45:44.553: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
(firefox-default:2772): Gtk-WARNING **: 20:45:44.635: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:2772): Gtk-WARNING **: 20:45:44.635: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
(firefox-default:2772): Gtk-WARNING **: 20:45:44.661: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(firefox-default:2772): Gtk-WARNING **: 20:45:44.661: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
[Child 2914, Main Thread] WARNING: JSWindowActorChild::SendRawMessage (Conduits, ConduitClosed) not sent: !CanSend() || !mManager || !mManager->CanSend(): file /builddir/build/BUILD/firefox-113.0/dom/ipc/jsactor/JSWindowActorChild.cpp:57
[Child 2951, Main Thread] WARNING: JSWindowActorChild::SendRawMessage (Conduits, ConduitClosed) not sent: !CanSend() || !mManager || !mManager->CanSend(): file /builddir/build/BUILD/firefox-113.0/dom/ipc/jsactor/JSWindowActorChild.cpp:57
[ERROR viaduct::backend::ffi] Missing HTTP status
Последний раз редактировалось deusdara 23 май 2023, 02:50, всего редактировалось 1 раз.
deusdara
VictorR2007 писал(а): 11 май 2023, 13:55 This seems to be a problem with the new mesa.
and then update.
x11]
name=x11
gpgcheck=0
enabled=1
cost=998
[x11-32]
name=x11-32
gpgcheck=0
enabled=1
cost=1000
Draguljche
Operating system: ROSA Fresh Desktop 13.0 (fresh-desktop) x86_64
Сообщение Draguljche »
Try like this, he made a mistake in writting.
[x11]
name=x11
gpgcheck=0
enabled=1
cost=998
[x11-32]
name=x11-32
gpgcheck=0
enabled=1
cost=1000
Пока нашёл только такое решение, которое помогло мне на ASUS K53.
Нужно установить пакет lib64dri-drivers-amber-21.3.9
из этого контейнера
http://abf-downloads.rosalinux.ru/victorr2007_personal/container/4664102/x86_64/main/release/
После этого нужно запускать firefox командой
MESA_LOADER_DRIVER_OVERRIDE=i965 firefox
Можно отредактировать его запуск через редактор меню.
Тут можно почитать про MESA_LOADER_DRIVER_OVERRIDE=i965
https://wiki.archlinux.org/title/Intel_graphics_(%D0%A0%D1%83%D1%81%D1%81%D0%BA%D0%B8%D0%B9)
Старый драйвер OpenGL (i965)
В Mesa 20.0 для Gen8+ по умолчанию используется новый OpenGL-драйвер Iris. Некоторые приложения работают с ним быстрее. Вы можете отключить его и вернуться к использованию старого драйвера i965, установив переменную окружения MESA_LOADER_DRIVER_OVERRIDE=i965 перед запуском любого приложения OpenGL. Эта настройка не влияет на приложения Vulkan.
So far I have found only such a solution that helped me on ASUS K53.
Need to install package lib64dri-drivers-amber-21.3.9
from this container
After that, you need to start firefox with the command
You can edit its launch through the menu editor.
Here you can read about MESA_LOADER_DRIVER_OVERRIDE=i965
Вернуться в «ROSA Fresh R12 (2021.1)»
