Terminal formatting problem after last Plasma update
trencan
Сообщение trencan »
Hello,
today I got big Plasma update. After that, when I open terminal window, I see more spaces after each word. Also when I type, I see cursor like 3 spaces behind the text I am typing. So the formatting is not very readable, probably some bug? Any hints?
Thanks.
The problem may be in the font: change the monospaced font. In the KDE menu, find settings, and click on System Settings app,
Now go to the Fonts tab,
trencan
Сообщение trencan »
Hello, I changed there in "Fixed width" Monospace to Sans Serif or Serif, but didn't help. Other hints? Thanks.
trencan
Сообщение trencan »
Btw. problem is not when I run Konsole via CTRL+ALT+F3 for example or I boot to single user mode. But just when I run Konsole from Plasma.
